MIG-29, 3000mm, Tetris, Bukvorez.
  • MIG-29, 3000mm, Tetris, Bukvorez.
    The new development, MiG-29-3000mm, the first cut in September.
    AW: MIG-29, 3000mm, Tetris, Bukvorez.
    Das währe auch mal was für mich
    habt ihr schon eine preisvorstellung ?
    Beste Grüße : Jan !
    RC-Fliegerhorst
      Hallo Max
      3000mm ist ein langer
      Reg, Egor.
        ???. . . .Wie viel $ €
        Beste Grüße : Jan !
        RC-Fliegerhorst
          Jetzt kann ich nicht sagen. alles, was werden mit dem vollen Material von Schneidemaschinen sein
            Ok Danke !
            Beste Grüße : Jan !
            RC-Fliegerhorst
              carbon
                Preliminary calculations show that the set of MIG-29-3000mm is a 3 pack 650x650x200mm.
                Here the 1/6 of model. Soon cutting.
                  update
                    Sehr Schön
                    Habt ihr schon € $ ?
                    Beste Grüße : Jan !
                    RC-Fliegerhorst
                      hoffe sehr, dass in den kommenden Feiertagen, wird bereit sein, nur das erste Blatt
                        Cut 1/6 model.
                        Footage 1/6 model was 74 meters. You can already estimate.
                        X 6 sheets (approx) = 444 meters of cut, almost - 25 hours of cutting.
                        And it is only when the СNC.
                        Plus, remove and put forth. Issued in 30 hours.
                        This has not happened
                          Master model 3 meters.
                          First let's try scaling the model with 1 mm increments in the lower side of 3000mm.
                          The minimum acceptable size, in this approach, will be 1400-1500mm in length.
                          As a result, approximation of the layer is reduced, which has a positive effect on the accuracy
                          production model, but it increases the build time model.
                            Only for fans of our tetris.
                            Big Mig-29-3000mm
                            At present, prepared 4 sheets of 6.
                            1. 74.12 m 136 items
                            2. 69.79 m 112 items
                            3. 64,01 m 134 items
                            4. 62.8 m 120 items
                            5.
                            6.
                            Thus we already have 270.72 m cutting CNC and 502 parts and more than 15 hours of CNC.
                            Under test (case) assembly looking for a room with a ceiling height of 3.8-4m.
                            Watch for updates.
                              MIG-29-3000mm
                              5.5 sheets, packing size 650x650x600, 3 parcels.
                              Wait for updates
