Chester's Goon 75% (Planung für 2014)
  • Chester's Goon 75% (Planung für 2014)
    Moin Moin
    Es ist ja wieder Winter und im Winter beginnt bei mir die Planphase für Folgeprojekte :
    Was ich für 2014 plane ist die Umsetzung eines knuffigen Racers aus den 1930iger Jahren
    im Masstab 1-1,5 oder 75% von der originalgröße !
    Da ich mit der Ultimate und dem Stingray werscheinlich früher
    fertig werde als geplant habe ich die Planung etwas vorgezogen
    hier ist das Flugzeug über das ich rede :
Größe: 16,2 KB
ID: 271250Klicke auf die Grafik für eine vergrößerte Ansicht
Größe: 17,0 KB
    Auszug aus Wikipedia :
    The Chester Goon aka The Chester Special #2 was a single engine taildragger configuration monoplane racer built for the 1938 National Air Races.
    Design and development
    Art Chester followed on his successful air racer the "Jeep"" with the Goon. "Goon", like "Jeep" was named after characters in Popeye cartoons.
    The Goon was built with a conventional welded steel tube frame and fabric covering. The wings used spruce spars and plywood covering. The mid-wing taildragger aircraft featured short-legged retractable landing gear. The engine was prepared to turn clockwise in anticipation of mounting a custom French propeller, but the propeller was also customized for American engines, and the engine needed to be modified again to rotate normally.[1]
    During the 1956 rebuild, a 190 hp Lycoming O-435-1 engine was installed in place of the Menasco, including a cut down Beech-Roby propeller and wheel brakes.
    Operational history
    • 1938 Placed second in the Greeve Trophy Races of the National Air Races with a speed of 250.42 mph (403 km/h).
    • 1938 Thompson Trophy - Has to drop out after failure of prop.
    • 1939 National Air Races - First place at 263.39 mph (424 km/h), winning $9000.[2]
    • 1939 Thompson Trophy - Dropped out with engine trouble.
    In 1939 20th Century Fox featured the Goon in the movie series Tailspin Tommy. By 1956, the was Goon purchased in unflyable condition. On December 23, 1957 the rebuilt Goon was test flown by Harvey Mace at Sacramento, California.[3]
    The Goon was purchased in 1991 by the Crawford Auto-Aviation Museum and was awaiting restoration in Macedonia,Ohio.[4]
    Specifications (Chester Goon)
    Data from EAA
    General characteristics
    • Crew: One
    • Length: 20 ft 6 in (6.25 m)
    • Wingspan: 18 ft 6 in (5.64 m)
    • Powerplant: 1 × Menasco C-6-S Buccaneer Inline six cylnder, 450 hp (340 kW)
    • Propellers: 2-bladed French Ratier Controllable
    Einen Kanidaten für den Motor habe ich auch schon ins auge gefasst :
    http://www.limflug.de/de/products/engines-15kw-40kw.php
    (Ist die 37KW Variante)
    Ich überarbeite gerade Pläne eines kleineren Modells :
    http://jan-herzog.net/app/download/5785564934/Goon.pdf
    Der Rumpfquerschnitt am Motorspannt beträt etwa 70x100cm^^
    Das Abfluggewicht wird soo etwa 75-90Kg betragen . . . . das ist kein Witz
    Ich halte euch was die Planung angeht auf dem Laufenden !
    Zuletzt geändert von Maximilian Thermidor; 13.12.2012, 19:30.
    Beste Grüße : Jan !
    RC-Fliegerhorst
    AW: Chester's Goon 75% (Planung für 2014)
    2014... Ich weiß nicht mal was ich 2012 zu Weihnachten verschenken soll.
      Ich muss das so lange im Voraus planen sonst ist es nicht durchführbar
      Das mit den Weihnachtsgeschenken kenne ich . . . . . . ich muss da auch noch sachen besorgen
      Beste Grüße : Jan !
      RC-Fliegerhorst
        Darfs ein bischen mehr sein? Ich dachte das Projekt Aurora geht mal weiter.
          Das ist vorerst auf eis da sich der Airframe nicht wirklich gut bauen lässt (Belastungen zwichen den Gondeln) , leider ist das Strömungsverhalten auch nicht wirklich gut und muß überarbeitet werden . Wenn ich die "Wohnzimmer" Funtana Fertig ist (maximal 5 tage) will ich ein überarbeites Styrodur Impellermodell bauen Spannweite etwas über 120cm. Ein virtueller flieger der Aurora Fliegt schon aber mit dem Sim zur realität ist das so eine Sache !
          Das Material für den Goon (Sperrholz,Alu,Holme,Kiefernleisten und Biegesperrholz fur die Verplankung) bekommt man relativ leicht im Baumarkt ich rechne mit Materialkosten von Maximal 1500€ für den rohbau des Goon . Bei der Aurora im Endmaßstab sind das rund 7000€ (nur für das Rohbau Material). Da ich mit den Goon materialen Besser umgehen kann und der Bau vergleichsweise besser um zu realisieren ist habe ich mich für den Goon entschieden !
          Mein Aktueller Plan für das Frühjar 2013 sieht vor :
          Ultimate:
          -Seilzüge verlegen
          -Rumpfverkabelung
          -Bespannen+grundieren
          -Motoreinbau
          Stingray :
          -Rohbau Fertigstellen
          -verkabeln
          -Servoeinbau
          Sommer 2013
          -Nemere+Willy Rohbau fertigstellen
          Spätsommer 2013
          -Stingray bespannen und Lackieren
          Herbst 2013
          -Nemere und Willy fertigstellen
          Soweit erstmal
          Beste Grüße : Jan !
          RC-Fliegerhorst
