The new development, MiG-29-3000mm, the first cut in September.
MIG-29, 3000mm, Tetris, Bukvorez.
AW: MIG-29, 3000mm, Tetris, Bukvorez.
Das währe auch mal was für mich :anmach:
habt ihr schon eine preisvorstellung ? -
Hallo Max
3000mm ist ein langer
Reg, Egor. -
???. . . .Wie viel $ € :^^:
Jetzt kann ich nicht sagen. alles, was werden mit dem vollen Material von Schneidemaschinen sein
Ok Danke !
carbon
Preliminary calculations show that the set of MIG-29-3000mm is a 3 pack 650x650x200mm.
Here the 1/6 of model. Soon cutting.
update
Sehr Schön :prost:
Habt ihr schon € $ ?
hoffe sehr, dass in den kommenden Feiertagen, wird bereit sein, nur das erste Blatt
Cut 1/6 model.
Footage 1/6 model was 74 meters. You can already estimate.
X 6 sheets (approx) = 444 meters of cut, almost - 25 hours of cutting.
And it is only when the СNC.
Plus, remove and put forth. Issued in 30 hours.
This has not happened
Master model 3 meters.
First let's try scaling the model with 1 mm increments in the lower side of 3000mm.
The minimum acceptable size, in this approach, will be 1400-1500mm in length.
As a result, approximation of the layer is reduced, which has a positive effect on the accuracy
production model, but it increases the build time model. -
Only for fans of our tetris.
Big Mig-29-3000mm
At present, prepared 4 sheets of 6.
1. 74.12 m 136 items
2. 69.79 m 112 items
3. 64,01 m 134 items
4. 62.8 m 120 items
5.
6.
Thus we already have 270.72 m cutting CNC and 502 parts and more than 15 hours of CNC.
Under test (case) assembly looking for a room with a ceiling height of 3.8-4m.
Watch for updates. -
MIG-29-3000mm
5.5 sheets, packing size 650x650x600, 3 parcels.
Wait for updates
update 2-12-2013
update
ready BIGMIG, MIG-29-3000mm!
began in August 2012th ending December 2013
5.5 sheets, packing size 650x650x600mm, 3 parcels.
1. 74.12m 136 items
2. 69.79m 112 items
3. 64.01m 134 items
4. 62.8m 120 items
5. 47.7m 48 items
6. 25.1m 14 itemsCNC 343.5 m
564 items -
Hello , Can you send me the price , ilike to order one :cool:
