Der sieht ja schonmal mehr als nur heiß aus:
http://www.hobbyking.com/hobby…ri_Copter_Frame_KIT_.html
Features:
• Unique full-body fiberglass construction
• Beautiful high gloss paint job
• Full body design makes for easy orientation while flying
• All metal pivot tail motor mount
• LED strip mounting grooves
Specs:
Width: 525mm (motor shaft center to center between front arms)
Length: 550mm
Frame weight: 460g (w/out electronics)
Flying weight: 900~950g (w/out battery)
Requires:
28-XX brushless outrunner motor x 3
25~40A brushless ESC x 3
High speed micro servo for the tail x 1
8x4~10x4.7 propeller x 3 (2 standard/1 reverse rotation)
Multi-rotor control board
2200mAh 3S lipoly battery
4CH transmitter and receiver
